LuckyNo13 Posted November 23, 2021 Share Posted November 23, 2021 Hey guys might be a crazy question but my old pc does not have a 3d graphics card and can't afford to buy new one right now.. i have HD Pro 2022 and need to produce a 2d view of the exterior is that possible ? Sorry i am new to this stuff... Thank you! Chris Home Designer Pro 2022 Link to comment Share on other sites More sharing options...
DavidJPotter Posted November 23, 2021 Share Posted November 23, 2021 2D exterior views are called "Elevations and cross sections", have at them using your elevation cross section camera to obtain them. What on Earth computer do you have please???? DJP Link to comment Share on other sites More sharing options...
LuckyNo13 Posted November 23, 2021 Author Share Posted November 23, 2021 Hey David, Thanks for the help! Haha it was beefy when i bought it (maybe 10 yrs ago?) - Dell Desktop i7cpu 2.67Ghz with 8G RAM. im running Windows 10 but video card will not do 3D. it does what i need but since i started dabbling with my house plan i re-discovered how old it is haha! I'll see if can figure out the Elevations and Cross Sections, so far just playing with the inside layout, etc.. Thanks, Chris Link to comment Share on other sites More sharing options...
Kbird1 Posted November 23, 2021 Share Posted November 23, 2021 39 minutes ago, LuckyNo13 said: Hey guys might be a crazy question but my old pc does not have a 3d graphics card and can't afford to buy new one right now.. i have HD Pro 2022 and need to produce a 2d view of the exterior is that possible ? Sorry i am new to this stuff... Thank you! Chris Home Designer Pro 2022 The Home Designer Series has it own Forum over here : https://hometalk.chiefarchitect.com/ However if you are getting an Error in X13 cos of low GPU then I'd suggest trying HD Pro 2021.... which has lower specs Even Elevation Views are technically 3D in Chief/HD , so David's advice may still not Help? You can do your Forum(s) Signature with the help of David's Video so people know what you're using both software and computer wise.... https://chieftalk.chiefarchitect.com/topic/18908-signature-here-at-chief-talk/?tab=comments#comment-155662 Mick. Link to comment Share on other sites More sharing options...
Dermot Posted November 23, 2021 Share Posted November 23, 2021 The information below applies to all or our products but the links are specific for Home Designer. All elevation and cross section views are actually 3D views. If your computer is not capable of creating 3D views, you will not be able to create them. You will likely have problems even just using basic plan views because we use 3D views all over the program including in most dialogs and in the library browser. I recommend reviewing the system requirements here: https://www.homedesignersoftware.com/products/system-requirements.html If your computer does not meet the minimum system requirements, then you might want to either upgrade your system or talk to customer service about what your other options are. If your computer does meet the system requirements but you are still having problems creating 3D views, you may want to review this tech article: https://www.homedesignersoftware.com/support/article/KB-00897/troubleshooting-3d-camera-view-display-problems-in-home-designer.html If all else fails, you may want to contact our technical support team for additional help: https://www.homedesignersoftware.com/support/#contact Link to comment Share on other sites More sharing options...
LuckyNo13 Posted November 23, 2021 Author Share Posted November 23, 2021 Hi Dermot, Yes i discovered yesterday that my system in fact does not meet the requirements.. You're correct - I can't even generate 2D Elevaton/Cross Section views. I am renting the software right now so i will make a decision soon.. would love to upgrade my system maybe next year. Thank you for your reply! Happy Thanksgiving! Chris Link to comment Share on other sites More sharing options...
Kbird1 Posted November 23, 2021 Share Posted November 23, 2021 1 hour ago, LuckyNo13 said: Hi Dermot, Yes i discovered yesterday that my system in fact does not meet the requirements.. You're correct - I can't even generate 2D Elevaton/Cross Section views. I am renting the software right now so i will make a decision soon.. would love to upgrade my system maybe next year. Thank you for your reply! Happy Thanksgiving! Chris You should Call Sales and explain the Situation and see if they will let you Rent 2021 instead , as it has the Old 3D Engine and will likely work on your Older System until you can upgrade. Mick. Link to comment Share on other sites More sharing options...
LuckyNo13 Posted November 23, 2021 Author Share Posted November 23, 2021 Okay thanks Mick i will give them a call and see what they say... so you think 2021 will render 2D views without meeting requirements of the new graphics card ? Link to comment Share on other sites More sharing options...
Kbird1 Posted November 23, 2021 Share Posted November 23, 2021 5 minutes ago, LuckyNo13 said: Okay thanks Mick i will give them a call and see what they say... so you think 2021 will render 2D views without meeting requirements of the new graphics card ? You haven't done your Forum signature , ( see mine for example below) so I have no idea what your computer specs are ? There is a whole new 3D Engine in Chief and HD this version around and there are quite a few who no longer meet the Specs , even though X12 and HD 2021 worked just fine. Mick. Link to comment Share on other sites More sharing options...
