builtright3 Posted November 14, 2021 Share Posted November 14, 2021 The only way I can get the Dutch gable to automatically build is to make the garage ceiling a different height. But then my facia doesn't line up and other things don't work right. Can anyone help me with this or do I have to create a work around? ANY HELP WOULD BE APRECIATED THIS IS WHAT I DONT WANT THIS IS WHAT I WANT Link to comment Share on other sites More sharing options...
Kbird1 Posted November 14, 2021 Share Posted November 14, 2021 Without the plan , the only suggestion I can think of is make sure the Front Wall ( red scribbly line in pic) is not 1 wall break it at the Garage if needed and set it to Hip. M. Link to comment Share on other sites More sharing options...
builtright3 Posted November 14, 2021 Author Share Posted November 14, 2021 22 minutes ago, Kbird1 said: Without the plan , the only suggestion I can think of is make sure the Front Wall ( red scribbly line in pic) is not 1 wall break it at the Garage if needed and set it to Hip. M. Been there done that, I should have explained it to you that I broke the wall. Thank You! Link to comment Share on other sites More sharing options...
builtright3 Posted November 14, 2021 Author Share Posted November 14, 2021 3 minutes ago, solver said: I reported this same problem to Chief when the Dutch Gable option was introduced. Can't imagine how things like this slip through testing as this is a really common configuration. You can force the program to generate the dutch gables by using Roof Groups, but you will still need to do clean up. Thank you Solver! I was afraid you might give me the answer I didn't want to hear. I'm best off at this point to draw it manually like I usually do. Link to comment Share on other sites More sharing options...
glennw Posted November 15, 2021 Share Posted November 15, 2021 Iy looks like Chief is trying to build a hip and a valley in the same location and is getting confused. Can you put a step in the side wall? Link to comment Share on other sites More sharing options...
