zowie123 Posted November 6, 2021 Share Posted November 6, 2021 Hi all, I've never made sense of the Minimum Display Size control which is supposed to control the size of dimensions when you scroll in and out. This control can be found in the Preferences dbx under Appearance--last item in the box. See images. zero or 1 is supposed to stop dimensions from changing size, then you can increase the size with a higher number. Dimensions still scramble when I use a 1 or zero in the size. . I'm working on something small and it would be great if the dimensions wouldn't scramble. Anyone ever figure this out? Thank you, Barry Link to comment Share on other sites More sharing options...
Solution Kbird1 Posted November 6, 2021 Solution Share Posted November 6, 2021 Leave it on Zero..... The issue here I think though is you need to make a new Dimension Default for working on smaller Areas eg CAD Details.... ie. make a 1" scale , 2" scale and 3" scale Dimension default. ie 1" Scale you haven't done you Sig. so no idea which version you are or etc https://chieftalk.chiefarchitect.com/topic/18908-signature-here-at-chief-talk/?tab=comments#comment-155662 1 Link to comment Share on other sites More sharing options...
rwdozier Posted November 6, 2021 Share Posted November 6, 2021 I have my Dimensions: set to 8 pixels in appearances and haven't encountered what you are referring to when working with something small. For small work, I set the Dimension Line Specification to smaller number heights. CA version? 1 Link to comment Share on other sites More sharing options...
zowie123 Posted November 7, 2021 Author Share Posted November 7, 2021 Thank you both. That makes sense. Cheers! Link to comment Share on other sites More sharing options...
