Renerabbitt Posted November 4, 2021 Share Posted November 4, 2021 For those times you just need to show a concept: 2021-11-04 12-49-37.mp4 2 2 Link to comment Share on other sites More sharing options...
mtldesigns Posted November 4, 2021 Share Posted November 4, 2021 Always a genius. I think about 75% have B&B.. going to try this next time. Material region works great, but does take time. Link to comment Share on other sites More sharing options...
HumbleChief Posted November 9, 2021 Share Posted November 9, 2021 That was great Rene but I'll be darned if I understood any part of the video. I did understand the polyline from the floor plan then choose an 'example' for a distributed path, which looked like the 'boards' of the B & B then select a bunch of icons that look unique to your work flow and voila, B & B siding? Not sure what happened while selecting the walls and other parts and pieces but the result looked great. I'll review a few more times and see if I can understand what exactly you did. Thanks Link to comment Share on other sites More sharing options...
cjanderson66 Posted November 9, 2021 Share Posted November 9, 2021 On 11/4/2021 at 1:52 PM, Renerabbitt said: For those times you just need to show a concept: 2021-11-04 12-49-37.mp4 5.49 MB · 0 downloads Rene, do you think you can slow this down a bit and add some voice over for clarification. I had to watch it 10X just to get one portion of it. :-) 1 Link to comment Share on other sites More sharing options...
Renerabbitt Posted November 9, 2021 Author Share Posted November 9, 2021 Ive had flooding at my place, moved out, and left my mic behind by accident.@HumbleChief and @cjanderson66 "Example" is a P-solid that I converted to a fixture and then designated as a freestanding range. It is 200" tall, 1" depth, and 12" wide and is a few inches AFF. The key element is specifying it as a range in the symbol options. Then: I clicked on the exterior room and created a polyline Converted the polyline to a distributed path, selected the range. Specified 15" intervals for a 3" Batten(12" symbol) Then I copied the path to the floor above Pull a 3d view and explode the lower distributed path. With the Backsplash Tool, clicked on the spaces between on the lower floor first. Explode the upper, click on the spaces on the upper floor. Dragged the bottom of the upper floor up Use the Delete Items Tool and select fixtures. Please keep in mind this is not perfect. You could get it perfect by breaking the line segments of the distributed path, but at that point it would be faster just to draw your 1 batten and then distribute in plan view. Link to comment Share on other sites More sharing options...
