cjanderson66 Posted November 2, 2021 Share Posted November 2, 2021 my address has changed and I want to update the existing layout sheets with a new template. How do I go about doing so? Anybody got any ideas of how to make this change. Link to comment Share on other sites More sharing options...
Solution rgardner Posted November 2, 2021 Solution Share Posted November 2, 2021 24 minutes ago, cjanderson66 said: my address has changed and I want to update the existing layout sheets with a new template. How do I go about doing so? Anybody got any ideas of how to make this change. Are you totally redoing your layout template or just your title block? If you just want to change your title block open up the new temlate and the old layouts and go to page 0 copy from new title block delete existing and paste hold position into the old layout. 1 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 2, 2021 Share Posted November 2, 2021 Hi CJ, If you have used the "Default Designer Info" in your template and past layouts you just need to edit that data to update your layouts. There are built-in macros in Chief to use that information. 1 1 Link to comment Share on other sites More sharing options...
cjanderson66 Posted November 2, 2021 Author Share Posted November 2, 2021 2 hours ago, rgardner said: Are you totally redoing your layout template or just your title block? If you just want to change your title block open up the new temlate and the old layouts and go to page 0 copy from new title block delete existing and paste hold position into the old layout. Ryan, Thank you for you expert advise. I knew it was something as simple as that and I just missed it. Chris Link to comment Share on other sites More sharing options...
