j2narchitecture Posted October 9, 2021 Share Posted October 9, 2021 When I export a cross section/elevation as a "cad detail from view", there a multiple layers of cad lines on top of each other. When I got to delete a cad line, there is another underneath. It takes a few times of deleting a line to finally remove it. Any way to prevent this from happening? See attached video clip. TIA. Recording #119.mp4 Link to comment Share on other sites More sharing options...
MPDesign Posted October 9, 2021 Share Posted October 9, 2021 Hi Jason, Try turning on the 3rd icon from the top on the right side of your screen. Has a red check mark. This will show you what layers the lines are on and can turn them off as needed. It also helps to turn off the layers you don't want before you send to cad. Link to comment Share on other sites More sharing options...
j2narchitecture Posted October 9, 2021 Author Share Posted October 9, 2021 Michael: Hi. Thank you kindly. Turning the layers off is def helping. Have a fab day! Link to comment Share on other sites More sharing options...
Kbird1 Posted October 9, 2021 Share Posted October 9, 2021 It's normal.... as Chief adds Cross Section Lines to all Elevation Views and they also go to the CAD Detail when exported, so you can end up with 2-3 layers of lines. M. Link to comment Share on other sites More sharing options...
