ChiefJeet Posted September 20, 2021 Share Posted September 20, 2021 In section view, the floor cuts through the inner leaf of the wall. Is there any way of making the wall continuous and for the floor to stop at inner face of the wall as shown in the clip? There is also a small gap above the internal wall and the floor. Plan attached. Thanks in advance Wall floor junction.plan Link to comment Share on other sites More sharing options...
rgardner Posted September 20, 2021 Share Posted September 20, 2021 Set up your wall defaults (or in this case change the individual walls) to hang floor system from wall. Link to comment Share on other sites More sharing options...
ChiefJeet Posted September 20, 2021 Author Share Posted September 20, 2021 Thank Ryan. Done that and now the floor board cuts through the wall. It is OK on the solid wall opposite. Also, I don't know why there is a small gap between the wall and the underside of the floor. For some reason, I can't attach the clip Link to comment Share on other sites More sharing options...
ChiefJeet Posted September 20, 2021 Author Share Posted September 20, 2021 The attachment icon in the topic box reads "Loading..." but does not allow me to add attachment. Sorry Link to comment Share on other sites More sharing options...
rlackore Posted September 20, 2021 Share Posted September 20, 2021 15 minutes ago, ChiefJeet said: now the floor board cuts through the wall. Maybe: Wall Specification>Structure>Platform Intersections>Ceiling Platform>Hang Floor Platform Above on Wall: check Subflooring to Wall Interior Link to comment Share on other sites More sharing options...
rlackore Posted September 20, 2021 Share Posted September 20, 2021 To get rid of the "small gap", select the interior wall: Wall Specification>Foundation: uncheck Sill Plate Link to comment Share on other sites More sharing options...
DavidJPotter Posted September 20, 2021 Share Posted September 20, 2021 Rather than carp (noting wrong with complaining) about the fact that Chief is not pre-programmed to do exactly as you wish when and as you wish, I would simply fix the elevation view with 2D CAD overlays so it "LOOKS" like you wish it to look (no one is ever going to "Live" in the virtual model contained in a " chief.plan or .layout file", those are used to emulate or graphically communicate ones desires to other building professionals. So you cover up the fact that Chief models a certain way using 2D CAD fill boxes so it "LOOKS" right when printed. It is unlikely that Chief will be rewriting its software to suit you and hundreds of other end users who are used to how some other software operates/ is programmed to work or how you think it should work-- it DOES work quite well and is able to, sometimes requiring some creative thinking, very well. DJP Link to comment Share on other sites More sharing options...
ChiefJeet Posted September 20, 2021 Author Share Posted September 20, 2021 45 minutes ago, rlackore said: Wall Specification>Structure>Platform Intersections>Ceiling Platform>Hang Floor Platform Above on Wall: check Subflooring to Wall Interior This works. Thanks 42 minutes ago, rlackore said: o get rid of the "small gap", select the interior wall: Wall Specification>Foundation: uncheck Sill Plate This does not work on the interior wall. . It appears as if the wall is providing a support to the floor and that little gap is a wall plate. I have deleted and built the wall again but the gap remains. Maybe it is associated with floor spec but I cannot seems to locate it. Thank you Rob. Your input has resolved some of the issues. Link to comment Share on other sites More sharing options...
rlackore Posted September 20, 2021 Share Posted September 20, 2021 Just now, ChiefJeet said: This does not work on the interior wall. . It appears as if the wall is providing a support to the floor and that little gap is a wall plate. It does work. Set you camera backclip to 0mm. Link to comment Share on other sites More sharing options...
ChiefJeet Posted September 20, 2021 Author Share Posted September 20, 2021 Thank you David but I was not complaining but looking for solutions if there are any. Some help from more experienced users has resolved some of the issues and there is less painting over for me to do. Link to comment Share on other sites More sharing options...
rlackore Posted September 20, 2021 Share Posted September 20, 2021 10 minutes ago, rlackore said: It does work. Set you camera backclip to 0mm. The reason you're seeing the "gap" after using my "fix" is because the camera is picking up the wall beyond, which also has a sill plate. With a concrete deck, I doubt that you want a wood sill plate on top of your masonry walls, so getting rid of the sill plate not only fixes the visual issue, but is probably more correct IRL. Link to comment Share on other sites More sharing options...
ChiefJeet Posted September 20, 2021 Author Share Posted September 20, 2021 10 minutes ago, rlackore said: t does work. Set you camera backclip to 0mm. .Yes it does work. I changed the backclip to 0, then 1000mm and then 2000mm. It appeared after 2m and found that it was the 9" circled wall causing it. I then changed its specification "uncheck sill plate" and it disappeared. Thank you Rob. Link to comment Share on other sites More sharing options...
