DeLayDesign Posted September 8, 2021 Share Posted September 8, 2021 My assumption was a partition wall simply meant it was not baring any weight, but it appears to have some different characteristics in chief and checking it makes it's connections awkward or not show up correctly. So? What is a partition wall and why would I check it? TIA Link to comment Share on other sites More sharing options...
HumbleChief Posted September 8, 2021 Share Posted September 8, 2021 Curious too. Did you check 'help' for a clue? Link to comment Share on other sites More sharing options...
HumbleChief Posted September 8, 2021 Share Posted September 8, 2021 Interesting, never knew that about 'partition walls.' Link to comment Share on other sites More sharing options...
DeLayDesign Posted September 8, 2021 Author Share Posted September 8, 2021 On 9/8/2021 at 1:56 PM, solver said: Did you read about it in Help -- button bottom right in your image. Expand Thanks! That helps. I'll look there first next time. Link to comment Share on other sites More sharing options...
DeLayDesign Posted September 8, 2021 Author Share Posted September 8, 2021 On 9/8/2021 at 1:57 PM, HumbleChief said: Curious too. Did you check 'help' for a clue? Expand I did; It was actually very helpful. I'm curious to see if it helps with some of the issues I've had using 'glass walls' in the past. Link to comment Share on other sites More sharing options...
HumbleChief Posted September 8, 2021 Share Posted September 8, 2021 On 9/8/2021 at 2:00 PM, DeLayDesign said: I did; It was actually very helpful. I'm curious to see if it helps with some of the issues I've had using 'glass walls' in the past. Expand I just used a 'glass wall' and in my Chief it defaults to 'partition wall'. Tried it with other walls and it seems to partition on one end but not both. Either way, learned something new today... Redefined an individual wall to partition and it behaves as defined in help. Cool. Link to comment Share on other sites More sharing options...
Kbird1 Posted September 8, 2021 Share Posted September 8, 2021 On 9/8/2021 at 1:59 PM, DeLayDesign said: Thanks! That helps. I'll look there first next time. Expand The F1 key will always bring up context sensitive help in CA too.... I find the Manual PDF easier to search in many cases than the new Online help though... Link to comment Share on other sites More sharing options...
