Joe_Carrick Posted December 23, 2014 Share Posted December 23, 2014 Mark, I suspect that CA created their door symbols by creating a rail and then copying that and rotating 90 degrees about the "y" axis to use as a stile. That way, the material is transformed 90 degrees the same as the stile rotation. It allows you to use a single material but get the grain to follow the length of the frame member. Link to comment Share on other sites More sharing options...
dshall Posted December 23, 2014 Share Posted December 23, 2014 Try using moldings for the rails. Link to comment Share on other sites More sharing options...
MarkMc Posted December 23, 2014 Share Posted December 23, 2014 Joe, the material doesn't rotate with the object. I tried faces to see if they work differently but rotate a face also altered the size for some reason?? Great idea Scott, it keeps the grain going properly but that makes a mitered door not a rail and stile door. Still very useful though don't use them often I just took on a line that has quite a few and does them well (rare) I was not looking forward to making them with solids. Wish I'd thought of that some time back when I had to do a bunch of floor inlays for a client- using my limited brute force tactics took some time, this is easy. Still wonder what the magic trick is? Is it a secret? Where's Doug? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted December 23, 2014 Share Posted December 23, 2014 Mark, I did a bit of experimenting and here's what I found: 1. I created a box 3" wide, 1" deep & 24" tall. 2. I assigned a wood grain material (vertical) 3. I converted this to a symbol called "Stick"4. I placed several of these in my plan and manipulated the width and height. Now here's the interesting part - the grain automatically aligns with the long axis. When I changed one of the symbols to 3" tall and 10" wide the grain became horizontal. This only works with the "Stick Symbol", not with the original primitive box. So the key is to use a piece that's been converted to a symbol to build your doors. Of course, if you need a special profile it takes a bit more work but the above rule still applies. Link to comment Share on other sites More sharing options...
MarkMc Posted December 23, 2014 Share Posted December 23, 2014 Youdaman you too Scott thanks guys. Sunyaer might want to mark this as solved. Link to comment Share on other sites More sharing options...
sunyaer Posted December 24, 2014 Author Share Posted December 24, 2014 Hi Mark, it seems these objects are not selectable. How to select and remove them (shown in the following attachment picture) from the model? Also, would you mind summarizing the steps creating the door given in your model by using the solution? If it would be great if a model could be provided as well. Link to comment Share on other sites More sharing options...
MarkMc Posted December 24, 2014 Share Posted December 24, 2014 They are on a Pdf so can't be selected. That layer is locked so you can trace them to make your own profiles. They are scaled to actual size and are common profiles. I drew a few and placed them on the side to show the needed orientation to have prior to sending to the library. Link to comment Share on other sites More sharing options...
