Markenbach Posted August 17, 2021 Share Posted August 17, 2021 Im making an commercial building and want the typical commercial building roof style (outer wall all the way up, then roof is lower then outside edge) I was looking at this method: https://www.chiefarchitect.com/videos/watch/1530/drawing-a-flat-roof-with-center-drain-and-parapet-walls.html but that seemed very complicated for something that should be relatively standard and I had thought there would be a more automatic way of doing this. Using Chief Architect Premier X12 Link to comment Share on other sites More sharing options...
rgardner Posted August 17, 2021 Share Posted August 17, 2021 There are other ways to do it and probably one of the more easier ways that I have found is create a 2nd (or 3rd if necessary) floor with no roof above set to the height of your parapet walls that you want. Then change the floor system to be what your roof system will be. On the main floor you will want to select your exterior walls and set them to hang floor system above on wall (usually with ledger) and the exterior walls above should be set to balloon frame through to floor below. 1 Link to comment Share on other sites More sharing options...
Markenbach Posted August 18, 2021 Author Share Posted August 18, 2021 thanks. I'll give that a shot and try to figure out what all that means! Link to comment Share on other sites More sharing options...
Alaskan_Son Posted August 19, 2021 Share Posted August 19, 2021 There are quite a few methods that can be used. A few things to remember though that will hopefully help you... Under normal circumstances and unless they're manually manipulated, walls will automatically build through until they hit a roof or ceiling plane. This means you can either drag walls up/down in 3D (not the most ideal) or keep your roof planes inside your walls. Under normal circumstances, unless they're manually manipulated, and unless they're under a roof or ceiling plane, walls will continue up until they reach the height of your defined ceiling. This means you could set the height of your parapet walls using the room ceiling height or by building roof planes directly over the walls. You can create a room's ceiling using a manual ceiling plane and/or by using the room's ceiling definition. This means your room definition ceiling height could set the parapet wall heights and a manually placed ceiling plane could be used for your actual ceiling. As Ryan already mentioned, you can use multiple floors to further add to your possible options. Link to comment Share on other sites More sharing options...
scottharris Posted August 24, 2021 Share Posted August 24, 2021 On 8/17/2021 at 3:29 PM, Markenbach said: ...I was looking at this method: https://www.chiefarchitect.com/videos/watch/1530/drawing-a-flat-roof-with-center-drain-and-parapet-walls.html There's a newer version of this video (at the same link) you might see if it helps. 1 Link to comment Share on other sites More sharing options...
