Corner Window Bug
Trawen
Go to solution Solved by Alaskan_Son,
Hi,
I was trying out Chief Architect X12 and wanted to do a corner window, but as you can see on the pictures, sash does not go all the way in the corner, but rather than that is cut off before it.
Does anyone have any suggestion how to solve this?
Thank you in advance.
(on the last picture there is also added a post, but that does not affect bug at all)
36 minutes ago, Trawen said:
I could not upload it here because of its size
Did you zip it ?  The plan must be closed in Chief while you do this
If still too big draw a small square house and try it in one Corner as a test --- still same issue? post that plan...
Nothing personal but you are new to the Forum , and I personally won't download files off an unknown website....
  • Solution
Its the Inset that Chief doesn't like.  Change the Inset to zero and it works.  I would recommend you report this to Chief as unexpected and undesirable behavior.  In the meantime you may end up needing to do that with multiple walls or a custom window symbol to get the inset look you're after.
