second floor deck posts and portico footings
Hammer7
Do deck posts display on 2?
Cylindrical posts, right?  Created with auto deck framing?  Drawn manually?  You know they're in the plan, right?  You can view the in 3D?
Post the plan.  Close the file before posting  it.  Zip it if it's too big, or put it in the cloud and provide the link.  You'll get your answer quickly by doing so.
If you used the post with footing tool they are showing on the same level as you placed the posts.  Go that level select and use cut, go to level 0 and paste in place.  Wont change them in 3d but will show them where you need on the foundation plan.
