buzzsaw204 Posted July 16, 2021 Share Posted July 16, 2021 hi, what is the Setting to cap/closed the end wall? this 3d view just show that it's not. Link to comment Share on other sites More sharing options...
Chopsaw Posted July 16, 2021 Share Posted July 16, 2021 Most likely you have a thin paint layer in your wall definition which should be logical but the software can't handle it properly. It works better to create a custom drywall material of your choice of color and it will wrap around your end walls. Link to comment Share on other sites More sharing options...
Kbird1 Posted July 16, 2021 Share Posted July 16, 2021 3 hours ago, Chopsaw said: thin paint layer in your wall definition Would be my guess too , it works on Ceiling but not on Walls in Chief as it is 0" thick. Mick. Link to comment Share on other sites More sharing options...
buzzsaw204 Posted July 16, 2021 Author Share Posted July 16, 2021 Link to comment Share on other sites More sharing options...
Kbird1 Posted July 16, 2021 Share Posted July 16, 2021 39 minutes ago, buzzsaw204 said: Exactly , that doesn't work ---don't add paint layers to wall definitions..( use the pattern color of the drywall ) ......remove both Neutral White Layers..... M. Link to comment Share on other sites More sharing options...
