Hardware Disappearing from Elevation Views
I know this has been reported, but I can't find the post with the solution.  Would someone mind commenting or pointing me to the correct thread?  Thanks, Kevin
What did Technical Support tell you?
Tech support told me nothing.  I read it somewhere on this forum.  It is my understanding from the thread that it has been reported.  I am not the one who found the bug.
2 hours ago, Kbird1 said:
Someone Mentioned doing a Cad Detail from View and Copying it back into the Elevation , until it is fixed.....
*found it finaly but doesn't say much more....
https://chieftalk.chiefarchitect.com/topic/31321-new-computer-questions/?do=findComment&comment=246908
Thanks Mick.  I tried several different searches all to no avail.
You should absolutely report it yourself if you want to see it fixed.
It would be redundant as Dermot has already stated they are working on it.  From Dermot in response to the original poster:
"Regarding the missing lines for cabinet hardware, I believe that this is the result of a bug in X13.  Upgrading your computer is very unlikely to have any affect on this.  We are currently working on a fix for this and hope to have it available in the next update.  For now, if you turn off color and then find you have some missing lines, they should come back if you use the Rebuild 3D tool.  You should always report these kinds of problems to our technical support team if and when you run into them."
Michael was just asking cos' They work on "Fixes" based on the number of bug reports , so the more reports the higher it goes on the List....
    29842
    jcobbinhi
    jcobbinhi
