winterdd Posted July 3, 2021 Share Posted July 3, 2021 I've only had this happen a few times where the stair cuts through another room (in this case the garage). How do you guys close it off? Link to comment Share on other sites More sharing options...
winterdd Posted July 3, 2021 Author Share Posted July 3, 2021 4 minutes ago, solver said: How would you close it off if you were building it? triangular floating wall lol....heck I don't know. Link to comment Share on other sites More sharing options...
SH_Canada Posted July 3, 2021 Share Posted July 3, 2021 don't show that 3d view and instead make a comment that it needs to be framed in. I've seen this on plans before 1 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted July 3, 2021 Share Posted July 3, 2021 31 minutes ago, ChiefUserBigRob said: triangular floating wall lol....heck I don't know. That's close. You should be able to edit the walls in elevation views. The other option is to use a PSolid 1 Link to comment Share on other sites More sharing options...
winterdd Posted July 3, 2021 Author Share Posted July 3, 2021 15 minutes ago, jasonN said: don't show that 3d view and instead make a comment that it needs to be framed in. I've seen this on plans before LOL, I have been known to do it that way but when I do a walk thru for the client I want it perfect. Link to comment Share on other sites More sharing options...
winterdd Posted July 3, 2021 Author Share Posted July 3, 2021 Solver and Joe, looks like I was on the right path then. Thanks Link to comment Share on other sites More sharing options...
rgardner Posted July 3, 2021 Share Posted July 3, 2021 Walls set to cut by roof and a ceiling plane placed under the stairs. Link to comment Share on other sites More sharing options...
