CaddCreations Posted June 29, 2021 Share Posted June 29, 2021 CA X12 Can't change the deck plank overhang. I have it set to 1-1/2". and it doesn't update from the factory default of 1/2" The planking is generated in the Room> Structure> Floor> Planks, Joists> Edit dialog Not in the floor finish section. (Been there, done that) I changed it in the room type defaults as well as the room specifications. I also have the auto framing turned off in both. Link to comment Share on other sites More sharing options...
Chopsaw Posted June 29, 2021 Share Posted June 29, 2021 Do you still have "Automatically regenerate deck framing." turned on ? 7 minutes ago, CaddCreations said: I also have the auto framing turned off in both. There is your problem right there. If you have edited a bunch of the other framing you can also manually edit the planking overhang. Link to comment Share on other sites More sharing options...
rgardner Posted June 29, 2021 Share Posted June 29, 2021 28 minutes ago, Chopsaw said: If you have edited a bunch of the other framing you can also manually edit the planking overhang. Just an fyi if this is the case and you are thinking it is a huge deal to manually edit the planking. Here is a trick, use cad lines and the extend to and cut tools to quickly extend all of the planks at once. With such a small change you may need to use two lines one quite a bit longer than you need to extend to, then another at the point you want to cut to in the right place. 1 Link to comment Share on other sites More sharing options...
