BruceKC Posted June 28, 2021 Share Posted June 28, 2021 Many of our new plans (for builders) are now deeper (front to back) than they are wide. They're too deep for a standard 24x36" Arch D sheet unless we change our construction drawing layout to Arch D in portrait mode...but that looks really weird, never seen one before. Anyone else have this problem? We're not sure what to do. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 28, 2021 Share Posted June 28, 2021 Start drawing the plans sideways, rotate layout box, or change scale would be my first few choices. Link to comment Share on other sites More sharing options...
richoffan Posted June 28, 2021 Share Posted June 28, 2021 Do it all the time. Basic architectural drafting standard (at least when I learned it in the 60's) is the main entry faces the bottom of the sheet or the right. When I change to a smaller scale such as 1/8" I send as a key plan and separate into 1/4" plans at logical and clearly marked break lines Link to comment Share on other sites More sharing options...
Kbird1 Posted June 28, 2021 Share Posted June 28, 2021 I usually Rotate the Layout Box , but sometimes even that is not enough if the local jurisdiction requires 1/4" scale as many do.......then ARCH_E1 is needed Link to comment Share on other sites More sharing options...
BruceKC Posted June 28, 2021 Author Share Posted June 28, 2021 Thanks everyone! I appreciate your input! Link to comment Share on other sites More sharing options...
winterdd Posted June 29, 2021 Share Posted June 29, 2021 I have a set of plans right now from a client who hired me to make some changes since they couldn't get in touch with the previous designer. (retired a few years back). He had the home sideways which really throws you off looking at it when the main entry is to the right. I was taught from day one in college 25 years ago and then working with builders, do whatever it takes to make at least the floorplan 1/4"=1'-0". I have kept every single plan on 24x36 since. Here is an example of another home I just finished with your same situation. I will do this every time when the need arises. Link to comment Share on other sites More sharing options...
