ACADuser Posted June 24, 2021 Share Posted June 24, 2021 I was able to make a steep stair by adjusting the overhang but the treads overhang the sides as well. Tried adding a wall next to the stair but an invisible wall will not trim the overhang but a regular wall will. Maybe I missed a setting. The stair could be pushed up against the exterior wall but needs to be trimmed on the interior side. I tried to use a railing wall but it will not follow stairs if over the right overhang. Link to comment Share on other sites More sharing options...
ACADuser Posted June 24, 2021 Author Share Posted June 24, 2021 This is more of what I was after. Perhaps I should just use solids to make it? Link to comment Share on other sites More sharing options...
DzinEye Posted June 24, 2021 Share Posted June 24, 2021 30 minutes ago, ACADuser said: This is more of what I was after. Perhaps I should just use solids to make it? Well... as per your pic, generally the tread gets fairly narrow in a 'ladder' stair....but I was able to get what you want.. Link to comment Share on other sites More sharing options...
DzinEye Posted June 24, 2021 Share Posted June 24, 2021 Use the closed sided stringers option then the exagerated tread overhang won't apply to the side. Edit: While the 'closed sided' stringer does the trick I actually used the custom stringer option and set the above and below numbers to zero to reduce the stringer size as much as possible. ( I hid the stringer so you could see the tread size and overhang) Link to comment Share on other sites More sharing options...
ericepv Posted June 24, 2021 Share Posted June 24, 2021 Is this what you're after? (attached) Steep Stairway.plan 1 Link to comment Share on other sites More sharing options...
ACADuser Posted June 24, 2021 Author Share Posted June 24, 2021 That looks very nice. Off to early dinner so I'll study it when I get back. Thanks Link to comment Share on other sites More sharing options...
ACADuser Posted June 24, 2021 Author Share Posted June 24, 2021 That works well for my planning plan. Thanks Link to comment Share on other sites More sharing options...
ericepv Posted June 25, 2021 Share Posted June 25, 2021 Glad I could help. Link to comment Share on other sites More sharing options...
