Sleepytime28 Posted June 24, 2021 Share Posted June 24, 2021 Has anyone else noticed that in RTRT only the lights in the room you have the camera view in are in use? That's kinda a bummer for open stair wells. Is it possible to make all the lights turn on? I attached an image for reference. Link to comment Share on other sites More sharing options...
MarkMc Posted June 24, 2021 Share Posted June 24, 2021 1 hour ago, Sleepytime28 said: Has anyone else noticed that in RTRT only the lights in the room you have the camera view in are in use? Look into adjust lights? Link to comment Share on other sites More sharing options...
Sleepytime28 Posted June 25, 2021 Author Share Posted June 25, 2021 16 hours ago, MarkMc said: Look into adjust lights? I have tried that. Its weird. all my lights have the on column checked but the in use column unchecked. I am going to try and update my graphics card driver and see what happens. Link to comment Share on other sites More sharing options...
robdyck Posted June 25, 2021 Share Posted June 25, 2021 18 hours ago, Sleepytime28 said: Has anyone else noticed that in RTRT only the lights in the room you have the camera view in are in use? That's kinda a bummer for open stair wells. Is it possible to make all the lights turn on? I attached an image for reference. You're missing something in your settings because it's unlikely a graphics card issue. Can you post the plan? I'm sure it's just something you've overlooked or a setting you may be unaware of. Link to comment Share on other sites More sharing options...
MarkMc Posted June 25, 2021 Share Posted June 25, 2021 37 minutes ago, Sleepytime28 said: I have tried that. Its weird. all my lights have the on column checked but the in use column unchecked. I am going to try and update my graphics card driver and see what happens. Be sure maximum lights is set hi enough. If that doesn't solve it create a new light set and turn them on for that camera. Link to comment Share on other sites More sharing options...
Sleepytime28 Posted June 25, 2021 Author Share Posted June 25, 2021 I sure can post the Plan.Exercise Room.plan F.Y.I. this plan file was created in X12. I did a quick trial plan in a new file created in x13 and the lighting worked fine. Link to comment Share on other sites More sharing options...
MarkMc Posted June 25, 2021 Share Posted June 25, 2021 1 hour ago, Sleepytime28 said: I sure can post the Plan The only way to get it to work is to start the camera in the stairwell but it's hit or miss -sometimes lights will come on in room, most of the time not. Once in the room changing any settings for camera, render, or for lights makes the lights in the stair well turn off. Since I got it to work with a new X13 plan and I gather you did as well it must be an issue with plan being brought forward. I'd send it in to support. Link to comment Share on other sites More sharing options...
Sleepytime28 Posted June 25, 2021 Author Share Posted June 25, 2021 19 minutes ago, MarkMc said: The only way to get it to work is to start the camera in the stairwell but it's hit or miss -sometimes lights will come on in room, most of the time not. Once in the room changing any settings for camera, render, or for lights makes the lights in the stair well turn off. Since I got it to work with a new X13 plan and I gather you did as well it must be an issue with plan being brought forward. I'd send it in to support. My thoughts exactly. I already sent it to support. Thanks for your input. Link to comment Share on other sites More sharing options...
robdyck Posted June 25, 2021 Share Posted June 25, 2021 The only help I've got is to change all the lights...sorry! I deleted all the added lights and used the light fixtures only, with some edits to their light properties. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 26, 2021 Share Posted June 26, 2021 Did you try unchecking Automatic and just using a Light Set? Link to comment Share on other sites More sharing options...
MarkMc Posted June 26, 2021 Share Posted June 26, 2021 35 minutes ago, Alaskan_Son said: Did you try unchecking Automatic and just using a Light Set? I did. Link to comment Share on other sites More sharing options...
MarkMc Posted June 26, 2021 Share Posted June 26, 2021 48 minutes ago, Alaskan_Son said: Did you try unchecking Automatic and just using a Light Set? Did you manage to get that to work? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 26, 2021 Share Posted June 26, 2021 4 minutes ago, MarkMc said: Did you manage to get that to work? No. I didn't even open the plan. Just offering some quick thoughts in passing. Link to comment Share on other sites More sharing options...
Sleepytime28 Posted June 28, 2021 Author Share Posted June 28, 2021 I sent in in to support. They have the same suggestions as you guys. They said they will try to correct it in future releases. Link to comment Share on other sites More sharing options...
