Doug-ib Posted June 3, 2021 Share Posted June 3, 2021 As you can see, on the Left of the house the joist are in pairs of 3-4 in some areas even though i set the O.C to 24". anyone know what might be causing this? and any solutions. Link to comment Share on other sites More sharing options...
SNestor Posted June 3, 2021 Share Posted June 3, 2021 It's a Chief thing. Chief automatically places double joists under walls. 1 Link to comment Share on other sites More sharing options...
Doug-ib Posted June 3, 2021 Author Share Posted June 3, 2021 5 minutes ago, SNestor said: It's a Chief thing. Chief automatically places double joists under walls. AH, is there anyway to disable the feature? or i is just something that i should include in the general construction notes. Link to comment Share on other sites More sharing options...
SNestor Posted June 3, 2021 Share Posted June 3, 2021 No way to disable....there have been numerous requests to fix this behavior. 1 Link to comment Share on other sites More sharing options...
joey_martin Posted June 3, 2021 Share Posted June 3, 2021 3 minutes ago, Doug-ib said: is there anyway to disable the feature? Check your code book first. If using dimensional lumber it's still code to support those walls. Some situations with I joists will need the extra joists under those walls. 1 Link to comment Share on other sites More sharing options...
SNestor Posted June 3, 2021 Share Posted June 3, 2021 Yes...supporting walls in required but you can do it with blocking. Placing a solid joist under a wall creates all sorts of problems for mechanical trades. The first thing that will happen is your electrician or plumber will cut or drill your engineered i-joist in a location that destroys the integrity of the joist. Happens all the time... 1 1 Link to comment Share on other sites More sharing options...
Northriver Posted June 7, 2021 Share Posted June 7, 2021 On 6/3/2021 at 6:53 AM, joey_martin said: Check your code book first. If using dimensional lumber it's still code to support those walls. Some situations with I joists will need the extra joists under those walls. Unless your State amendments to the IRC require double joists under interior non bearing walls, the IRC does not require it.( R502.2). If the wall is a braced wall panel or an engineered shear wall you will need double joists, blocking or what ever the Structural Engineer requirements are. Link to comment Share on other sites More sharing options...
