HaikuDog Posted May 26, 2021 Share Posted May 26, 2021 I have created a vaulted ceiling, I can see from the wall angle that it has vaulted but the ceiling surface isn't showing up. What am I doing wrong here? Link to comment Share on other sites More sharing options...
Chopsaw Posted May 26, 2021 Share Posted May 26, 2021 Welcome to ChiefTalk. Everything in chief has a layer and to view the item it needs to be turned on in each view. Try turning on "Ceiling Surfaces in your camera view. Link to comment Share on other sites More sharing options...
HaikuDog Posted May 26, 2021 Author Share Posted May 26, 2021 It is on & vaulted ceilings in adjacent rooms are on. Under Tools, Layer settings, Display Options it is also turned on. Link to comment Share on other sites More sharing options...
Chopsaw Posted May 26, 2021 Share Posted May 26, 2021 Yes but you are likely trying to look at it in a 3D view. Is it turned on in your "Camera View Set" layerset ? Also for controlling layes the ALDO "Active Layer Display Options" tool is the most logical way to do it. Link to comment Share on other sites More sharing options...
HaikuDog Posted May 26, 2021 Author Share Posted May 26, 2021 It is on & vaulted ceilings in adjacent rooms are on. Under Tools, Layer settings, Display Options it is also turned on. example.pdf Link to comment Share on other sites More sharing options...
HaikuDog Posted May 26, 2021 Author Share Posted May 26, 2021 Link to comment Share on other sites More sharing options...
HaikuDog Posted May 26, 2021 Author Share Posted May 26, 2021 Those settings are as you have shown them above. I have attached the file here. I'm new to CA and self taught, forgive my ignorance here. I've gotten the vaulted ceilings to show in the adjacent machinery room but as you can see they don't show in the bedrooms. Pole Barn.plan Link to comment Share on other sites More sharing options...
SNestor Posted May 26, 2021 Share Posted May 26, 2021 13 minutes ago, HaikuDog said: Those settings are as you have shown them above. I have attached the file here. I'm new to CA and self taught, forgive my ignorance here. I've gotten the vaulted ceilings to show in the adjacent machinery room but as you can see they don't show in the bedrooms. Pole Barn.plan 11.05 MB · 3 downloads I opened your file...looks like the ceilings are all on to me. I would guess the layer set you are using for your view does not have ceiling surfaces turned on. Link to comment Share on other sites More sharing options...
HaikuDog Posted May 26, 2021 Author Share Posted May 26, 2021 I go to View/Active Layer Display Options and Ceiling Planes is checked. Link to comment Share on other sites More sharing options...
HaikuDog Posted May 26, 2021 Author Share Posted May 26, 2021 8 minutes ago, solver said: Thank you, though I'm not sure how you are seeing the ceilings in those bedrooms and I am still not. Link to comment Share on other sites More sharing options...
HaikuDog Posted May 26, 2021 Author Share Posted May 26, 2021 7 minutes ago, solver said: In your camera view, switch to the All On layer set, and make sure all layers are set to display. Always the first thing I do when something is not displaying. If it shows, then the problem is related to layer set display settings. Went to View/Active Layer Display Options, under layer sets selected All Layers ON and the ceiling is still not there in the two bedrooms and upper bath. Link to comment Share on other sites More sharing options...
HaikuDog Posted May 26, 2021 Author Share Posted May 26, 2021 Thanks for your help, I'll come back to it tomorrow and see if I can come up with a solution. Link to comment Share on other sites More sharing options...
Dermot Posted May 26, 2021 Share Posted May 26, 2021 You are using the Perspective Floor Overview camera. The overview cameras do not show ceiling surfaces because they are intended to be used to look into the model from above. Try using the Full Camera instead. 2 Link to comment Share on other sites More sharing options...
