SH_Canada Posted May 26, 2021 Share Posted May 26, 2021 when I watch https://www.chiefarchitect.com/videos/watch/6146/terrain-landscaping.html?playlist=39 https://www.chiefarchitect.com/videos/watch/75/terrain-site-plan-basics.html?playlist=101 the retaining wall bottom looks like it is at the bottom of the terrain. When I draw a retaining wall, it draws to the bottom of the foundation. All I want is a 1 foot retaining wall to even out the ground for stairs. Instead it builds it 8 feet and then drops the terrain behind it. Even if I go into elevation and resize to one 1 ft, it will not rebuild the terrain behind it to be only 1 ft. I tried with no luck changing the foundation defaults prior to building the terrain foundation wall: no luck changing the terrain skirt size changing the hieght of the wall in elevation view attaching it to the house foundation Seems so simple when I watch the videos. What am I missing? Thanks before: after when I change the wall size in elevation: Mark VR.plan Link to comment Share on other sites More sharing options...
glennw Posted May 26, 2021 Share Posted May 26, 2021 You need to tell the terrain what to do. Place an Elevation Line at 0" on the high side of the wall. Or, drag the Elevation Region so that its left hand edge is just on the high side of the wall. Place an Elevation Line at -12" at the low side of the wall. You can drag the top or bottom of the wall up or down to fine tune it. Link to comment Share on other sites More sharing options...
SHCanada2 Posted May 26, 2021 Share Posted May 26, 2021 Thanks, ironically, I did that (added in two lines,before and after) about the same time you were writing it. so good to know that is the correct way I watched the videos again, and the difference in size of retaining wall is her terrain does not go to the bottom of her foundation. Mine does because it is a walkout. So when she draws the terrain wall it is only a couple feet deep. Anyhow, thanks for helping. Link to comment Share on other sites More sharing options...
