tool bars
jerryajohnson35
You likely need to talk to tech support in the morning but check if there is anything in the Knowledge Base link provided in the Error Warning.
You could try looking in :
C:\Users\User\Documents\Chief Architect Premier X12 Data\Toolbars
And make sure the file is there.  If for some reason it has been corrupted make a copy of the backup file and name it the same as the original and change the name of the potentially corrupt original to something else to isolate it.
All at your own risk of course.   And be sure that the error comes up consistently a second time before you do any fiddling around.
I assume you got the error following Eric's instructions that are correct by the way ?
