DanceOfFaith Posted May 13, 2021 Share Posted May 13, 2021 Would anyone be wiling to convert a DWG file to PLAN format for me? I am only using the Suite version. Thanks Link to comment Share on other sites More sharing options...
DavidJPotter Posted May 14, 2021 Share Posted May 14, 2021 DWG files are natively 2D only. One imports the 2D file and then traces over its lines with 3D tools for walls, windows, doors etc.. It is not "click of a button" fast, the fully 3D model or .plan file takes time to recreate. One would have to see the complexity of the existing design in order to offer you a bid or estimate. DJP Link to comment Share on other sites More sharing options...
Chopsaw Posted May 14, 2021 Share Posted May 14, 2021 10 minutes ago, DavidJPotter said: One would have to see the complexity of the existing design in order to offer you a bid or estimate. Not sure that was the intent of the request. I don't think Suite has an option to import DWG. 4 hours ago, DanceOfFaith said: Would anyone be wiling to convert a DWG file to PLAN format for me? I am only using the Suite version. Why not post the file and consider it done. 1 Link to comment Share on other sites More sharing options...
DavidJPotter Posted May 14, 2021 Share Posted May 14, 2021 1 hour ago, Chopsaw said: Not sure that was the intent of the request. I don't think Suite has an option to import DWG. Current versions of Home Designer Software can import .dwg files (not true in the past) I assumed they wanted a fully 3D version of the 2D AutoCAD file for use in Home Designer Software. DJP 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted May 14, 2021 Share Posted May 14, 2021 1 Link to comment Share on other sites More sharing options...
DanceOfFaith Posted May 14, 2021 Author Share Posted May 14, 2021 Thanks for all the replies Only looking for 2D Correct Suite does not import DWG File is attached C-9935-05-12-21.dwg Link to comment Share on other sites More sharing options...
Solution Alaskan_Son Posted May 14, 2021 Solution Share Posted May 14, 2021 Here you go.... DWG Import.plan 1 1 Link to comment Share on other sites More sharing options...
DanceOfFaith Posted May 14, 2021 Author Share Posted May 14, 2021 17 minutes ago, Alaskan_Son said: Here you go.... DWG Import.plan 5.22 MB · 0 downloads Thank you very much! Link to comment Share on other sites More sharing options...
