Evolution Posted December 4, 2014 Share Posted December 4, 2014 The master bath has a window set high above the tub and built out from the main layer about 20". The lower part of the wall is also built out 20" behind the tub but the tub extends into the room from the main layer creating a hollow wall (20") deep behind the tub. How would you model this detail? Link to comment Share on other sites More sharing options...
DRAWZILLA Posted December 4, 2014 Share Posted December 4, 2014 I would treat this as a manually drawn box window, raise the wood floor to what you need, no foundation. Link to comment Share on other sites More sharing options...
Evolution Posted December 4, 2014 Author Share Posted December 4, 2014 Since I cannot select the bump out as a separate space to raise the floor, I would have to use the divider or invisible wall tool to create a room? Link to comment Share on other sites More sharing options...
Solution DRAWZILLA Posted December 4, 2014 Solution Share Posted December 4, 2014 Yes, create a separate room for the box out Link to comment Share on other sites More sharing options...
dshall Posted December 4, 2014 Share Posted December 4, 2014 Listen to P. Link to comment Share on other sites More sharing options...
dshall Posted December 4, 2014 Share Posted December 4, 2014 I did a vid on method awhile back. Involves putting in doorway between house and bay Link to comment Share on other sites More sharing options...
