Boxed Out Wall Above Tub And Under Window
Evolution
Go to solution Solved by DRAWZILLA,
The master bath has a window set high above the tub and built out from the main layer about 20". The lower part of the wall is also built out 20" behind the tub but the tub extends into the room from the main layer creating a hollow wall (20") deep behind the tub. How would you model this detail?
    31602
    1badbear
    1badbear
