designercats Posted April 8, 2021 Share Posted April 8, 2021 How do you delete a hatch on a floor plan. I'm using V12 of Chief Achitect Interiors. I added wall hatches on a floor plan. Im not able to turn off the layer. Link to comment Share on other sites More sharing options...
joey_martin Posted April 8, 2021 Share Posted April 8, 2021 Not enough info. Is the hatch a part of the wall default, hatch tool, etc... Link to comment Share on other sites More sharing options...
Chrisb222 Posted April 8, 2021 Share Posted April 8, 2021 1 hour ago, designercats said: I added wall hatches on a floor plan. Im not able to turn off the layer. Walls, Hatching is a stock layer that you should be able to turn off Maybe you're trying to select the hatching. I have to tab past the wall selection to get to the hatching Link to comment Share on other sites More sharing options...
Richard_Morrison Posted April 9, 2021 Share Posted April 9, 2021 If you select the wall hatching tool, you can Shift-Select and only pick up hatches. Link to comment Share on other sites More sharing options...
