Craigevans Posted December 4, 2014 Share Posted December 4, 2014 I am new with chief and I am having a problem. When I build a covered lanai or porch, I am building my tie beam by building a wall and using the pony wall as a room divider to allow for the height i need of the beam and also to provide an enclosed "room" space so I can set my ceiling heights. The only problem is that when I do this, the room divider is removing the siding at the point of contact with the exterior wall and I see the exposed structure of the wall. Can someone help with why this happening and how to fix it. Or if there is a better way to create a tie beam and still creat the "room for ceiling heights ect. Thanks! Link to comment Share on other sites More sharing options...
lbuttery Posted December 4, 2014 Share Posted December 4, 2014 Just guessing: try using an invisible wall instead of the room divider ??? choose or create an appropriate wall type and set it to invisible Lew Link to comment Share on other sites More sharing options...
rlackore Posted December 4, 2014 Share Posted December 4, 2014 Don't know what a lanai is. For a covered porch you could use a railing wall to define the extents of the porch, and use a soffit (or other method) for the tie beam (if I understand what you mean by a tie beam): Link to comment Share on other sites More sharing options...
rlackore Posted December 4, 2014 Share Posted December 4, 2014 On 12/4/2014 at 3:37 PM, NCC-1701 said: Lanai: a Hawaiian word for veranda... Veranda: Also, verandah. Chiefly South Midland and Southern U.S word for a large, open porch, usually covered... I Googled Lanai, didn't get any hits that made sense within the context. Thanks for the explanation. Link to comment Share on other sites More sharing options...
Craigevans Posted December 4, 2014 Author Share Posted December 4, 2014 Thanks so much for the help! By taking the wall and making it invisible that took care of the problem. I couldn't use the rail wall because I want the area open from all sides and the finished floor height is at ground height. Thanks again. This forum is great for help and the responses came a lot faster than I thought they would. This is a great resource especially for the newbie! Link to comment Share on other sites More sharing options...
DRAWZILLA Posted December 4, 2014 Share Posted December 4, 2014 For your wall not fully displaying correctly, check your roof edges to see that they don't go beyond the wall surface. Link to comment Share on other sites More sharing options...
