It is because you have the window top higher than the bottom of the floor joist of the level above.  Lower the windows.
They really don't like being there do they.  Try placing them on level 1 and then move them to their absolute position and it should work the way you want it to but you still have some floor framing to deal with somehow.
Placing the window on the 1st floor and moving it down should work, but then the window displays on the 1st floor.
You could break the bottom of the brick wall and pull it up so it goes over the window instead of through it.
Hi Eric,
how can I add the door and window sill as per the site picture
Eric, how do I add the sill for the window and door as per the site picture
thank you for the response. Its a finished basement, hence I could not measure the joist depth and you can see them in the site picture as how they look on site. I am trying to recreate for my drawings.. Do you know how could I add the sill thick as it appears in the site picture?
For the window you can draw the sill profile and put it into your library as a molding and then apply it to the window.
For the door I think you just need to use a p-solid.
    29852
    Defraven
    Defraven
  • Similar Content
    • By ChiefuserMathews
      is it possible to display the door size beside the door panel in the plan with a macro?
    • By SelahF
      My chosen floor keeps appearing black (it is medium walnut floor from the Chief Architect library). I tried to see if it was all of them, but it seems to just be this single flooring type. I haven't touched any of the display settings for it, so I'm at a loss. Any help? (I'm very new with Chief Architect so this might be any easy fix)
    • By DGail1
      At one time, the hinge/swing direction of cabinet doors was displayed in elevation views, but it isn't happening any more.  Is there a setting that I need to change?
    • By Ange822
      I am using Chief Architect Premier x9
      I have exported my chief file to a 3D viewer file so a client can look at it.
      When I went to open the file though, most materials are not there for example the siding is just shown as one solid colour vs a horizontal pattern.
      thanks in advance.
      Angela
    • By Ange822
      I am using Chief Architect Premier X9
      My defaults seemed to have changed so that when I select a window - it is now showing temporary dimensions of the window casing / center of window / trim. (see attached screen shots)
      How do I change this to only show the window opening to wall stud?
      thanks in advanced!
      Angela
