mazakintegrex Posted February 28, 2021 Share Posted February 28, 2021 are there any tricks to create block and masonry walls to course intervals? trying to accurately model cmu foundation walls to match full block and half block intervals I started with setting grid snaps to course intervals, but figured it won't hurt to ask how others go about Link to comment Share on other sites More sharing options...
mazakintegrex Posted February 28, 2021 Author Share Posted February 28, 2021 im talking more along the lines of floorplan wall length intervals vs the visual material texture. could just do the math.. but didn't know if there was an easier way or how others might go about taking waste/labor/overall vision into consideration during design phase trying to figure out how to convert what I know in one program to CA. example of what I'm talking about. Link to comment Share on other sites More sharing options...
joey_martin Posted February 28, 2021 Share Posted February 28, 2021 Open the pattern and adjust the verticle offset. Before..... After... Link to comment Share on other sites More sharing options...
Chopsaw Posted February 28, 2021 Share Posted February 28, 2021 20 minutes ago, joey_martin said: Open the pattern and adjust the vertical offset. You can also adjust the horizontal offset if you want it to display just so. Link to comment Share on other sites More sharing options...
mazakintegrex Posted February 28, 2021 Author Share Posted February 28, 2021 thanks to all! 26 minutes ago, solver said: What happens when you set the Snap Grid to 8"? once a wall is drawn off grid, it will not allow re-snapping to a grid line with a wall drag move- it moves at increments in which the grid distance is set? other than redrawing the plan, point to point move or dimension line the only way to get back on track? Link to comment Share on other sites More sharing options...
