Elevation Dimension From Slab Foundation
akabuilder
So I have a simple elevation problem where my dimension is showing an extra 1 5/8" (at the foundation level) that I am not sure where it is coming from. I have a 4" slab foundation with 8x16" footers and stepped FoxBLOX  along the sides as it is a partially underground. It does look as though  the slab is not sitting at the same level as the footers. It looks like it is 7/8" above the footers from the backclipped view. The Cross Section Elevation also has an extra 1 7/8" on my dimension string. My builder wants the basement to be 8' 1 1/2" . So I would like to eliminate this extra height.
Kent House STAIRS: Revised :Auto Dimension.pdf
Kent House STAIRS: Revised:North.pdf
Kent House STAIRS: Revised.plan
