chiefjdennis Posted February 21, 2021 Share Posted February 21, 2021 Hello, Does anyone know if there's a way to control camera orbiting while in perspective full overview? I'm not sure if this is a feature or anomaly but if while in perspective full overview you hold down the left mouse button and drag it off screen and release....your model will spin indefinitely. The speed with which you drag and release controls the spin rate. This gives the effect of a drone taking an aerial shot of your model while flying around it. You cant always get it to spin so I'm not quite sure how to control the spin rate more precisely.. any thoughts? Thanks, Jeff Link to comment Share on other sites More sharing options...
Chopsaw Posted February 21, 2021 Share Posted February 21, 2021 Ctlr + Alt + S is a better way to initiate the spin and the camera "Incremental Rotate Angle" determines the rpm. Every time you start will be in the opposite direction also. 1 Link to comment Share on other sites More sharing options...
AdamRB Posted January 3, 2023 Share Posted January 3, 2023 On 2/20/2021 at 8:46 PM, Chopsaw said: Ctlr + Alt + S is a better way to initiate the spin and the camera "Incremental Rotate Angle" determines the rpm. Every time you start will be in the opposite direction also. @Chopsaw How do I navigate to "Incremental Rotate Angle" ? Link to comment Share on other sites More sharing options...
DBCooper Posted January 3, 2023 Share Posted January 3, 2023 Camera dialog. 1 Link to comment Share on other sites More sharing options...
Dershem Posted April 6 Share Posted April 6 And how would you capture such a thing as a WMV? Link to comment Share on other sites More sharing options...
DBCooper Posted April 6 Share Posted April 6 Look through the 3D walkthrough tools. You might be able to get what you want using the "create orbital walkthrough path". Link to comment Share on other sites More sharing options...
