stager386 4 Posted February 10 I have watched the video about stretch planes and zones so many times and I still find it nearly impossible to control the changes I try to make on furniture. I am missing something in the concept of how to do it. I am trying to customize a bed by stretching the headboard only. I can't seem to make it work. And when I do play around with the stretch zones or planes, the image changes just by placing the zones, before I have even edited it, which adds to the confusion for me. Alternatively, I would create my own bed and headboard, but cannot make the solid polylines look soft like a fabric covered headboard would look, with padding and rounded edges. Are there any other instructional tools that I can go to? Thank you for your help! CA help with stretch zones.plan Share this post Link to post Share on other sites
Alaskan_Son 2615 Posted February 10 Are you trying to just make the headboard taller? Share this post Link to post Share on other sites
stager386 4 Posted February 10 1 minute ago, Alaskan_Son said: Are you trying to just make the headboard taller? No I am trying to make it the length of the wall, 12'. Share this post Link to post Share on other sites
Alaskan_Son 2615 Posted February 10 37 minutes ago, stager386 said: No I am trying to make it the length of the wall, 12'. This simply isn't possible to do with Stretch Planes or Stretch Zones. You'll need to either model it manually or break that symbol down into 2 parts and resize independently. Share this post Link to post Share on other sites
Joe_Carrick 2392 Posted February 10 Kate, Is the headboard currently wider than the rest of the bed? If so, you can just Place stretch planes on each side of the bed so they are just intersecting the headboard Do not check the Stretch Zone box When you place and resize the symbol you will need to open an select "Create CAD Block" Share this post Link to post Share on other sites
stager386 4 Posted February 10 2 hours ago, Joe_Carrick said: Kate, Is the headboard currently wider than the rest of the bed? If so, you can just Place stretch planes on each side of the bed so they are just intersecting the headboard Do not check the Stretch Zone box When you place and resize the symbol you will need to open an select "Create CAD Block" It is not bigger, no. Share this post Link to post Share on other sites
