Porches On X6
nick66
The Room Divider wall type does NOT need to be invisible. In fact, it's not set to "Invisible" in my template. It has a zero thickness &  "Air Gap/ No material" material definition so that the wall is completely transparent, even in vector views. I want it on "Walls, Normal" layer as a solid line in plan. If I don't want that line in plan, then I make it invisible & it automatically moves to the "Walls, Invisible" layer. Also, by NOT making it invisible, it never changes wall types on you when you're not looking. You will have to change the wall type of attic wall abv though- if necessary.
I think it was more confusing before. "Invisible" is NOT a wall type. It's a wall PROPERTY. Any wall type can be invisible, & often is. In prior versions, it did matter what wall type was used & made invisible in certain situations.
