RobWhite Posted January 22, 2021 Share Posted January 22, 2021 Is there a method to draw a fence over a retaining wall? Typically drawings a wall over a wall deletes the primary wall. The retaining wall is a 350 thick limestone wall and the fence over is a SS post and rail with horizontal SS cable infill. The balustrade is positioned central to the wall Link to comment Share on other sites More sharing options...
glennw Posted January 22, 2021 Share Posted January 22, 2021 Rob, I don't think you can do it with a retaining wall. But you can do it with a normal pony wall. I wouldn't use a retaining wall anyway - usually better to use a normal wall and a Terrain Break Link to comment Share on other sites More sharing options...
robdyck Posted January 22, 2021 Share Posted January 22, 2021 I use a pony wall for this. Otherwise, the fence and the retaining wall would need to be on different floors. However, for the fence you could also use a millwork panel ( or any other fixture or symbol) on a distribution polyline. This can work well for a fence style that will be stepped, NOT sloped. Link to comment Share on other sites More sharing options...
