ChiefUserBigRob 16 Posted January 19 ok, so where do we turn off moulding dims in NKBA? I have unchecked all the options except for cabinets and fixtures and still get these pesky things. Share this post Link to post Share on other sites
ChiefUserBigRob 16 Posted January 19 more, very aggravating and time consuming to pull the grips away. Share this post Link to post Share on other sites
MarkMc 540 Posted January 19 34 minutes ago, ChiefUserBigRob said: aggravating and time consuming Rob there is no worthwhile control over NKBA dims since they are supposed to match what the NKBA wants. I simply never use them. Instead I set up Default Sets to dimension only to desired things on a line. For instance- set to dimension to wall cabinets uses-layerset that only shows wall and tall cabinets , dimension default snaps to cabinets and casings having a proximity fixed to set dimension where I want set for base cabinets, layerset that only shows base, tall cabinets, and appliances, dimension default with different prox fixed etc. can set up centers for appliances. I also have sets for elevations Clicking drop down for dimension default and dragging a line, click for next and drag a line. A lot faster than clearing out little diamonds IMO. Share this post Link to post Share on other sites
ChiefUserBigRob 16 Posted January 19 yes, auto elevation dims works great. i just really like the centerline dims that NKBA throws in. thanks Share this post Link to post Share on other sites
rgardner 163 Posted January 19 4 hours ago, ChiefUserBigRob said: ok, so where do we turn off moulding dims in NKBA? I have unchecked all the options except for cabinets and fixtures and still get these pesky things. Kind of looks like you are using the 1/2” scale defaults and not your nkba defaults. Share this post Link to post Share on other sites
