erinmulhern Posted January 13, 2021 Share Posted January 13, 2021 I am having a problem with arrows that I have drawn from text to an object in my plan moving and/or changing. I will draw the arrow, send the view to layout, and then exit the drawings. When I re-open the files the text arrow will be in a different location pointing in a different direction. This doesn't happen to all of my arrows and it doesn't happen every time, just randomly (so it seems). Has anyone had a similar issue? I have attached a before and after picture to illustrate what is happening. Thank you! Erin Mulhern, Designer Spokane, WA Chief X12 Premier Dell Precision 7720, Win 10 Pro 64 bit Intel core i7-7700HQ (Quad core 2.8GHz, 3.8 GHz Turbo, 6MB 45W, w/Intel HD Graphics 630) 32GB, 2x16GB, 2400 MHz DDR4 Non-ECC SDRAM 512GB 2.5” 7mm SATA SSD Class 20 NVIDIA QUADRO P3000 w/6 GB GDDR5 HP & Dell 23” monitors Link to comment Share on other sites More sharing options...
rgardner Posted January 14, 2021 Share Posted January 14, 2021 Are you by chance opening it on a different computer, or someone else working on it? Link to comment Share on other sites More sharing options...
erinmulhern Posted January 14, 2021 Author Share Posted January 14, 2021 I always use the same computer and nobody else accesses my files. I do move the drawings to different monitors. Thank you for reading my question. Link to comment Share on other sites More sharing options...
Dermot Posted January 14, 2021 Share Posted January 14, 2021 By default, arrowhead lines can attach to other objects at both the head and tail. You can tell whether or not the arrow head or tail is attached by selecting it. If the end handle is filled, then it is attached. If the end handle is open, then it is not attached. If you move or resize an object that has an attached arrow, then the program will also move the arrow to keep it attached. If you want to disable this automatic behavior, you can turn off "Attach Head to Other Objects" and/or "Attach Tail to Other Objects" in the Line Specification dialog. The picture below shows an arrow attached to both a text object and a cabinet. If you move either the cabinet or the text, the arrow will move as well. I can't really tell much from your picture but it is possible that either the head or tail is connected to some other object then the one you thought it was. You may have modified this other object causing the arrow to move. 1 Link to comment Share on other sites More sharing options...
ACADuser Posted January 16, 2021 Share Posted January 16, 2021 I've found that using "Attach Tail to Other Objects" ONLY is the best for me. (Nothing else checked) If you attach the head and label a foundation, the arrow may attach to the foundation & any edit to the wall can cause the head of the arrow to jump. Link to comment Share on other sites More sharing options...
erinmulhern Posted January 20, 2021 Author Share Posted January 20, 2021 Thank you for your responses! Link to comment Share on other sites More sharing options...
