ChiefuserMathews Posted January 3, 2021 Share Posted January 3, 2021 Happy New Year when I generate the wall legends I am getting the extra lines in my schedule and I don't know where it is coming from. Could someone look at it and let me know what is causing the extra lines to generate. Attached is my plan for reference del wall legends.pdf del wall legend issue.plan Link to comment Share on other sites More sharing options...
Doug_N Posted January 3, 2021 Share Posted January 3, 2021 Wilson, I have no idea if this will fix your problem or not. This happened when I was using X11 and here was the answer from tech support. I thought it was fixed, so your problem may be unrelated. Doug Doug Norton Tuesday, Jul 16, 2019 - 09:06 AM PDT When inserting a wall schedule a strange vertical line appears when including 2d symbols for a default 8" concrete stem wall. How can I fix this? Support Answer - Grant Swenson Wednesday, Jul 17, 2019 - 02:02 PM PDT Doug, Our development team is still looking into how to properly correct the issue. However, we have found that if you turn off Slabs in your layer Display Options, the line will no longer appear in your schedule. Keep it mind that turning off the Slabs display in that layer set will also have it not show up in any other views using that layer set. Grant Chief Architect Technical Support Link to comment Share on other sites More sharing options...
ChiefuserMathews Posted January 3, 2021 Author Share Posted January 3, 2021 Thank you Doug for your quick response. That is strange. But I never had any issue in the past, only on this drawing. I may have to try on creating a new plan and see if this is repeating. Anyways thank you. Link to comment Share on other sites More sharing options...
rgardner Posted January 3, 2021 Share Posted January 3, 2021 Had the exact same issue that technical support was unable to replicate. It would go away when I resized the column with the 2d symbol. Link to comment Share on other sites More sharing options...
