Shed roof Truss
rck-tech
For that room, uncheck 'Flat Ceiling Over This Room'. Then adjust the structure thickness of your roof plane to match the depth of the parallel chord truss (or draw a ceiling plane with the same slope as the roof plane). Then you can draw a truss. You might need to adjust the shape of the truss envelope a bit. You can also edit the truss detail to customize the webbing to match your picture if you want.
    31405
    MCDCINC
    MCDCINC
