LevisL Posted October 27, 2020 Share Posted October 27, 2020 Wondering if there's an easy way to get the posts and beams to show up in camera views in this case where I have a deck with wraparound stairs and post-to-beam railings? The automatic doorways are making the railing walls invisible and I can't delete these doorways, just resize them. Am I missing something?! I know I could manually add the posts and beams, but if I can get this to work, it would be easier... especially if the client decides to change the deck size later on. Link to comment Share on other sites More sharing options...
joey_martin Posted October 27, 2020 Share Posted October 27, 2020 WALLS>DECK RAILS layer, or WALLS>RAILINGS...depends on what you used. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted October 27, 2020 Share Posted October 27, 2020 I’m with Joey. Looks like you probably just need to turn the layer on. Link to comment Share on other sites More sharing options...
LevisL Posted October 27, 2020 Author Share Posted October 27, 2020 The layer is on. The problem is the doorways that are automatically created at the top of the stairs. They span from corner to corner. In doing so, Chief seems to make the whole wall invisible. If I make the doorways narrower, then I get posts and beams. Problem is I just want one post on each corner. I'll post a simple plan shortly. Link to comment Share on other sites More sharing options...
LevisL Posted October 27, 2020 Author Share Posted October 27, 2020 Here's a simple plan showing the same problem. Post to Beam Example.plan Link to comment Share on other sites More sharing options...
LevisL Posted October 27, 2020 Author Share Posted October 27, 2020 Perfect. Thanks Eric. That's exactly what I needed! Link to comment Share on other sites More sharing options...
