mpatalsky Posted March 7, 2014 Share Posted March 7, 2014 Could anyone shed some light on how you go about getting Chief setup to build like this picture? I have tried so many ways & I wasn't able to get it to draw correctly. I am using X6. Thanks, Mike Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 8, 2014 Share Posted March 8, 2014 I only spent a few minutes setting this up, but check out my settings. Hopefully it helps. Make sure you define your garage as a garage. Adjust the garage slab through the room structure DBX on the foundation level. Link to comment Share on other sites More sharing options...
dshall Posted March 8, 2014 Share Posted March 8, 2014 Mike, do you want to explain why he must call it a garage? Hey Mike, can't you see Russia from Wasilla? Link to comment Share on other sites More sharing options...
mpatalsky Posted March 8, 2014 Author Share Posted March 8, 2014 I set it up that way. I swear it is IMPOSSIBLE to get it to respond like I drew the 2D CAD above. This is how I build a house & I can't get it to behave this way. Test.planFetching info... Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 8, 2014 Share Posted March 8, 2014 On 3/8/2014 at 8:17 AM, dshall said: Mike, do you want to explain why he must call it a garage? Hey Mike, can't you see Russia from Wasilla? Using the garage room type automatically sets the structure settings close to what the OP was after. And no, we can't see Russia from Wasilla : ), although there ARE a lot of Russian people here. We can however see Russia from one of the islands on the Aleutian chain. There are 2 islands that are only about 2-1/2 miles apart. Edit: Sorry, I guess I didn't look closely enough at the picture in the original post. I didn't realize the slab was on top of the foundation. You may not want to use the garage room type like I said afterall. You can, but it will require just as much structure modification as any other room type (maybe more)... Link to comment Share on other sites More sharing options...
Solution Alaskan_Son Posted March 8, 2014 Solution Share Posted March 8, 2014 I didn't spend too long on it, but check out the attached plan to get a rough idea of what to do...(or what I would do anyway)... There may be another way, but one of the keys is to open the walls around the garage (you may need to place some break points) and then under the structure tab check "go through floor below" Test.zipFetching info... Link to comment Share on other sites More sharing options...
joey_martin Posted March 8, 2014 Share Posted March 8, 2014 Admittedly I have not tried, but off the top of my head....raise the garage slab and set the foundation offset of the wall to get it to move under the raised slab. Link to comment Share on other sites More sharing options...
mpatalsky Posted March 9, 2014 Author Share Posted March 9, 2014 Thanks Michael! I played around with all of those numbers within the dialog box but I couldn't get it to behave that way. I would of never thought to break the walls & check the , "go through floor below" box. Again, thanks so much! Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 9, 2014 Share Posted March 9, 2014 You're welcome:) Link to comment Share on other sites More sharing options...
mpatalsky Posted March 10, 2014 Author Share Posted March 10, 2014 On 3/9/2014 at 8:15 PM, Alaskan_Son said: You're welcome:) As with my experience with Chief... I tried doing the steps you have explained in my own work & it doesn't work!!!!!! When I try to change the numbers in the dialog boxes, Chief changes the others incorrectly. Do you have any suggestions? Thanks, Country Home.planFetching info... Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 10, 2014 Share Posted March 10, 2014 Can you be more specific?? If I understand correctly, among other things... 1. Open the garage room dbx on the 1st floor and on the structure tab uncheck "floor supplied by the foundation room below" 2. Open the garage area room dbx on the foundation level and on the structure tab uncheck "roof over this room" and "floor under this room". Also, change the "ceiling finish", "floor finish", and "floor structure" dimensions to zero. There are probably other things you'll need to mess with, but with the limited information I have, that's what I can offer. Link to comment Share on other sites More sharing options...
mpatalsky Posted March 10, 2014 Author Share Posted March 10, 2014 Ahhhh, I didn't catch those two things. Unchecking the "floor supplied by the foundation room below" is what wouldn't allow me to manipulate the different fields without automatically changing others. Again, thank you! Link to comment Share on other sites More sharing options...
