RL-inc Posted November 12, 2014 Share Posted November 12, 2014 I am trying to find a Dacor symbol catalog for use in CA X5. The website seek.autodesk.com has several file types available for download but I am not sure that any are compatible with CA for symbol content. Does anyone have experience in using the file types available from Autodesk or similar in CA? thanks Link to comment Share on other sites More sharing options...
Kbird1 Posted November 12, 2014 Share Posted November 12, 2014 if you mean the Appliances try 3D warehouse https://3dwarehouse.sketchup.com/search.html?q=dacor&backendClass=entity Link to comment Share on other sites More sharing options...
DavidJPotter Posted November 12, 2014 Share Posted November 12, 2014 if they are available from Autodesk then they are probably available in AutoCAD native 3D dwg format which can be directly imported, a symbol at a time using the "Symbol Wizard" in Chief and then added to your LB. DJP Link to comment Share on other sites More sharing options...
RL-inc Posted November 13, 2014 Author Share Posted November 13, 2014 David that was the perfect trick - thank you Link to comment Share on other sites More sharing options...
