SLOWWW plan file suddenly
Renerabbitt
  On 9/9/2020 at 11:14 PM, TheKitchenAbode said:
The two Pantry's, bathroom vanity and shower shelf are where the problem is. Once I deleted them the plan runs as I would expect on my Spectra 360. On your system it should be fine.
Expand
You're the man!!
It was the 2 linen closets like you mentioned..THANK YOU!!!!
  On 9/10/2020 at 12:44 PM, TheKitchenAbode said:
You are very welcome Rene.
Fortunately your plan was not overly complicated so it was not too time consuming to narrow it down.
Cheers,
Graham
Expand
I was just getting started on it..and it is a full home remodel ..was confusing to me that it suddenly came to a crashing hault. I had at least a couple sessions with those cabinets so I don't know what changed. Thanks again
Expand
The only time I have had something like that is if I've used a high resolution texture and then in the texture DBX I had set the size to something like 1/16" X 1/16". As you can surmise, replicating a very high resolution texture that many times over say a 10 sq.ft. surface is a lot of work.
  On 9/10/2020 at 10:29 PM, Alaskan_Son said:
By the way, your issue is just being exacerbated astronomically by the fact each one of those doors has roughly 2,000 faces.  If one single projected plane is producing 62,000 lines, imagine all the lines being produced in a full 3D view.  YIKES!!
Expand
All makes sense to me, just not sure what happened ..one day was working fine and the next was crashing,,,no changes in between..even went back a version and the same problem existed. I think maybe a material file got replaced at its core location.
