Can this be modeled in Chief?
GeneDavis
As you can see, the fascia is neither square nor plumb.   And the soffit is dropped, with a blocked-out frieze below.
I created the roof with a flat planar roof plane with baseline at wall line (outside face of main layer). Outside that is another roof plane, curved, specified to have the right radius and tangent characteristics.  That roof plane cannot be specified with a boxed soffit.  I tried.  No go.  Maybe it is because it is not "on" the wall, but is outboard of it.
It appears as if to get reasonably close to what this is, I will need to do a molding, the shape of it the whole soffit box and the frieze.  The back-cut fascia with the crownmold?  Forgettaboutit.
What would you do?
2020-09-09 15_06_42-20_0827 DeHaan SD Pricing Set.pdf - Adobe Acrobat Reader DC.png
