BelfastCNC
Default siding shows up on to of inside walls
If I change the default siding on exterior walls and build a house with no flat ceiling then add interior walls i end up with
the default (changed) exterior siding on the top of walls. if i do not change the default siding it puts drywall top and bottom
depending on direction drawn the error occurs either inside the room or outside
If I am understanding your question, Could be two things;  One you painted the wall.  If you did, changing the default won't correct the wall.  You will need to delete and redraw.  If that's not the case, see if this works; Go to the wall DBX,and on the roof tab, check the lower wall and then pick the wall you want showing on the interior side.
You probably need to say exactly what and how you are doing things that result in the problem you have shown.
I opened X10 and could not reproduce.
Attaching your plan showing the problem would also be helpful.
It looks like you may have an error with your wall definitions.  But as mentioned above we do not have enough information to help you.  Post the plan for best results.
1.       Open New Plan Chief Architect Premier X10
2.       Edit-Reset to Defaults, All Floors, select all default boxes
3.       Default Settings-Walls-Exterior Walls, Edit, Materials, Exterior Surface (Lap Siding), Select Material, Select Cream Board & Batton, Click OK,
4.       Click OK on Exterior wall Defaults
5.       Click Done on Default settings
6.       Draw 20’x20’ Exterior wall building
7.       Open wall specification dialog box, select roof, the select full Gabe Wall, Click OK
8.       Do step 7 on the opposite wall
9.       Place to cameras on opposite diagonal corners
10.   Walls may or may not have the original default “Blue Siding” or the default I selected “cream Board & Batton” it seems that if I draw walls CW they all end up as blue siding but if I draw them CCW the first wall is Blue siding and the rest are correct cream board 7 baton.
11.   In camera view use Material Eye Dropper to sample a correct wall then use material painter to correct walls that have Blue Siding to Cream Board & batton
12.   Save Plan
13.   Select Room (Entire House) Open room specifications
14.   Select Structure, Deselect Flat Ceiling Over this Room, Click OK
15.   Place a Camera inside house at corner pointed diagonally across house
16.   Open build roof dialog select build roof plane, Click OK
17.   Interior walls on including gables are all dry wall inside and board and baton outside
18.   Draw L shape interior walls from Gable end to a side wall
19.   Sometimes just the upper section of the wall shows the exterior siding some times even a lower wall has the exterior siding
20.   In camera view use Material Eye Dropper to sample a correct Drywall wall then use material painter to correct walls that have exterior siding to be drywall
I included the plans at different point in the process
Wall Proble Rev A all walls corrected.plan
Wall Proble Rev A Messed up 2 interior walls.plan
Wall Proble Rev A.plan
I was able to reproduce easily in X12.
I drew one structure and got this.
Then drew another in the same plan and got this.
Instead of changing the material, create a new wall type with the material you want. When I did this, walls were correct.
That did the trick.  One other issue i found is if i draw one of the walls right on the centerline of the roof it draws a top wall all the way across the building
Only way i found to fix is go to atic in plan add break at corner and then make the bad piece invisible
You should be able to drag that attic wall back instead of making it invisible.
I tried to reproduce in X10, but could not.
    28415
    HeartAlba
    HeartAlba
