Macro Question-Consolidating macros
Renerabbitt
I have a bunch of simple string macros as well as some integer macros in my template plan. I would love to be able to consolidate them into one macro as global variables. Is this possible?
Currently I have a jobInfo macro where I type in all of the details of a job such as
$wallInsulation = "R-19 Batt Fill"
$wallFraming = 24 (then a separate macro that translates this to a string)
Etc.
Each of these then has a corresponding macro filling up my macro management.
Things that are visually "busy" tend to be hard for me to process. I would love to limit the number of macros by consolidating.
Thanks in advance
So if I understand the request you would have one json file for constants like this:
# my job constants
$wallFraming = 24
and so on
And include the macros like this?
    "UserDefinedMacro": {
        "Name": "Railing Exterior",
        "Value": "42\" Guard Rail",
        "ShouldEval": false,
        "Context": "none",
        "RubyAPIVersion": 1
I know I do not have the syntax correct but I have seen all macros in one json file.
Perhaps I miss understood the request.
It is more about how are you use these macros....
I had a similar dilemma and realized it is easy to simple define the spec macros [non-Ruby] and only import from the file system what I need. In a folder I have 4 or 5 different definitions of: A_SPEC_FNDWALL_TALL9 (8" or 10"), only one json with 8" for ex will be imported. You can multi-select and import as many macros as you want at one time. If you have macros that do analysis: once they generated the results (I pasted them into a text) they are no longer needed. Personally I used SPEC macros and couple label (custom labels) and that was it.
The minor / short strings can go into keynotes or just a small text
All visible text here generated by %A_SPEC_XXX% macros
What I believe Rene is talking about is using one single macro to set all sorts of global "Job Information" variables such as
$My_name = "Michael"
$Wall_framing = 24
$Project_zip_code = "98765"
$Setback = 40.ft
...and so on
...and then defining another macro for each and every one of those variables so he can use the values elsewhere...
What I was trying to point out is that all those secondary macros are no longer necessary in X12.  You can delete all except the job_info macro and simply place your global variable name directly into a text box, callout, or wherever you want to use it...
In fact, you don't even need the job_info macro either.  Those global variables can even be defined in a text box.  In X12, I believe I could literally delete all my macros if I wanted to and just use single line code typed directly into text boxes.  Not that I would want to do that, but I could. The only thing I'm really not sure of is how many commands Ruby will allow to be entered in a single line of code.
Interesting, could you think of a use case?
I had responded earlier and deleted my response realizing that I was missing the $ sign to call out a global from the jobinfo macro. You summed it up nicely and am in the process of deleting a ton of macros...so THANK YOU!
I still have questions about the measurement/float changes that I may post about if I don't manage to figure it out myself.
There are a ton of things I use this behavior for all the time.  It's a lot quicker and easier to create, edit, copy and paste a text box than it is to create, edit, copy, and paste macros for specific purposes and commonly its a lot more convenient to write a quick one-time-use macro in place than it is to create a custom macro for the purpose.
6 minutes ago, ACADuser said:
Just to be clear, using the "job_info" macro with all the global variables, do you need to execute it somehow?
Or just having the macro in the macro list is enough to initialize the values?
It needs to be executed.
I personally just usually put it somewhere where it’s displayed all the time but not visible (either off screen or set to display an empty string).
I tried $test = "testing this out" in a text box and then placed %$test% in a text box and it did not work, what am I missing?
PS I know it's probably annoying educating someone that doesn't know the basics or even classifications but it is how I learn, single case uses at a time :)
Here’s a quick starter kit I set up a little while back for use in X12 that requires no custom macros in TMM whatsoever.  Just copy and paste the following text into your plan and/or layout...
Project Information
Designer:
$Designer_Company = %$Designer_Company = "ASC"%
$Designer_Name = %$Designer_Name = "MC"%
$Designer_Phone = %$Designer_Phone = "(888) 123-4567"%
Client:
$Client_Name = %$Client_Name = "Mr. and Mrs. Jones"%
$Client_Phone = %$Client_Phone = "(888) 123-4567"%
Builder:
$Builder_Company = %$Builder_Company = "Super Duper Builders"%
$Builder_Supervisor = %$Builder_Supervisor = "Mike Smith"%
$Builder_Phone = %$Builder_Phone = "(888) 888-8888"%
Other:
$Project_Name = %$Project_Name = "Smith Residence"%
$Zoning = %$Zoning = "R-2"%
$Setback_Side = %$Setback_Side = 10.ft%
$Setback_Front = %Setback_Front = 25.ft%
$Property_Address =
%$Property_Address = "1234 Main St.\nAnchorage, AK 99515"%
Just use this as a template and add your own project information variables.  Those variables can then be typed into any valid data entry field using the %$Variable_name% format.  You just need to make sure the text box is displayed in any and all views that use the information.  Just drag it off to the side.
Anyway, feel free to use my “starter kit“ to your hearts content but consider contacting me directly with any questions or if you want to dig deeper and really learn more of the basics.
  • Upvote 2
