rockyshepheard Posted August 28, 2020 Share Posted August 28, 2020 Hi, Does anyone know what CA thinks it is doing by filling in white between windows when you get close enough? Is this a vestigial casing? Link to comment Share on other sites More sharing options...
glennw Posted August 28, 2020 Share Posted August 28, 2020 Windows will automatically mull together when their internal casings touch? Although without a plan it is a bit hard to tell what is happening in this case. Link to comment Share on other sites More sharing options...
rockyshepheard Posted August 28, 2020 Author Share Posted August 28, 2020 Not sure what you mean by mulled. What is purpose of mulling? version 11.plan Link to comment Share on other sites More sharing options...
glennw Posted August 28, 2020 Share Posted August 28, 2020 Yes, it is what I said - Automatic Mulling. Occurs when the casings touch. In this case it is caused by the size of the internal casings. Chief will "join" the windows with a single casing - same as like you would do in real life. If the windows were dragged together closer than the casing width, what would you want to happen? Delete the casings? Overlap the casings? Make 1 small and 1 big?.......... Auto mulling is different from manual mulling in that the windows remain as individual windows whereas with manual mulling the windows join together to form a single window unit. 1 Link to comment Share on other sites More sharing options...
rockyshepheard Posted August 28, 2020 Author Share Posted August 28, 2020 But casings are turned off. I would want no respect for casings, given that. So you could put them as close as you want, when casings turned off. That would seem to be better. Do you agree? Maybe good suggestion for suggestion box. Link to comment Share on other sites More sharing options...
Chopsaw Posted August 28, 2020 Share Posted August 28, 2020 35 minutes ago, rockyshepheard said: But casings are turned off. I would want no respect for casings, given that. So you could put them as close as you want, when casings turned off. That would seem to be better. Do you agree? The odd thing is that it is caused by the interior casing setting. Might be something to look into for sure. Maybe what Glenn said that the program is letting you know there is an issue but I did not know window were that smart. 1 Link to comment Share on other sites More sharing options...
glennw Posted August 28, 2020 Share Posted August 28, 2020 2 hours ago, rockyshepheard said: But casings are turned off. No they aren't. Your exterior casings are off - your interior casings on on. It is the interior casings that are causing the auto mulling. 1 Link to comment Share on other sites More sharing options...
glennw Posted August 28, 2020 Share Posted August 28, 2020 2 hours ago, rockyshepheard said: I would want no respect for casings, given that. So you could put them as close as you want, when casings turned off. That would seem to be better. Do you agree? Maybe good suggestion for suggestion box. I'm not sure I follow you. Can't we already get windows as close as we want? Link to comment Share on other sites More sharing options...
rockyshepheard Posted August 28, 2020 Author Share Posted August 28, 2020 2 hours ago, glennw said: No they aren't. Your exterior casings are off - your interior casings on on. It is the interior casings that are causing the auto mulling. So smart! Thank you! Link to comment Share on other sites More sharing options...
