crosscutter55 Posted August 25, 2020 Share Posted August 25, 2020 I am hoping there is someway to create a small sub division in chief x10.The sub division is 120 2 acre lots . I need it so I can plot road & drainage areas for asphalt . This would also help to note lots that might require drainage pipes in front of existing & potential driveways.I would like to send thise to a 13x 19 layout sheet. This doesnt have to be 100% accurate I can write road dimensions on the plan Link to comment Share on other sites More sharing options...
Ridge_Runner Posted August 25, 2020 Share Posted August 25, 2020 Pardon my ignorance, but can you actually apply/read any notes on that many 2-acre lots plotted to a 13x19 sheet? Link to comment Share on other sites More sharing options...
NCC-1701 Posted August 25, 2020 Share Posted August 25, 2020 Yes you can. I've done much larger layouts for impervious surface calculations, etc. Mike, you print out many, many 13x19 sheets . Maybe a key map on one sheet that references the others... Link to comment Share on other sites More sharing options...
crosscutter55 Posted August 25, 2020 Author Share Posted August 25, 2020 Yes I do have all these lots plotted on a 13 x 19 sheet , i might be able to trace over that plan Link to comment Share on other sites More sharing options...
joey_martin Posted August 26, 2020 Share Posted August 26, 2020 Are you asking how do do it? Link to comment Share on other sites More sharing options...
Ridge_Runner Posted August 26, 2020 Share Posted August 26, 2020 I was thinking all the lots (entire subdivision) on one sheet, thus the question. Link to comment Share on other sites More sharing options...
