Sign in to follow this
crosscutter55
small sub division
I am  hoping there is someway to create a small sub  division in chief x10.The sub division is 120   2 acre lots . I need it so I can plot road & drainage areas for asphalt . This would also help to note lots that might require drainage pipes in front of existing & potential driveways.I would like to send thise to a 13x 19 layout sheet.
                   This doesnt have to be 100% accurate I can write road dimensions on the plan
Pardon my ignorance, but can you actually apply/read any notes on that many 2-acre lots plotted to a 13x19 sheet?
Yes you can. I've done much larger layouts for impervious surface calculations, etc.  Mike, you print out many, many 13x19 sheets ;).  Maybe a key map on one sheet that references the others...
             Yes I do have all  these lots plotted on a 13 x 19 sheet , i might be able to trace over that plan
I was thinking all the lots (entire subdivision) on one sheet, thus the question.
    28448
    Burtonmadness
    Burtonmadness
