Split roof help
josbrp
  On 8/14/2020 at 1:43 PM, josbrp said:
do you mind sharing the file with the roof like that? i get big gaps on the walls when i edit the roof planes manually.
thanks
Expand
Is it possible you manually adjusted your walls in an elevation mode?  If so that turns off the automatic wall sizing you want  on to fill the "gap".  Select all of your walls in plan view, open the wall dbx and on the structures tab make sure the first two radial buttons (default wall top and bottom height). is checked.  That should fix the "gap" problem.
Expand
they are checked. does not let me to change that
thanks
Expand
I can't share the file - I'm on X12, and you won't be able to open an X12 file on X11. Refer to the Reference Manual, I think it can get you headed in the right direction:
Expand
If they are set to automatic heights that means there is an invisible wall that is in that same space keeping the attic walls from being built.  Go to your attic level, turn on attic and invisible walls and delete them all twice with auto attic wall build turned on.  Should clean it up.
